Flandy Rv-10
RV-10
FWF Day #12 and interior
Tracey came out and installed rear headliner panels and passenger footwell carpets.
Continued fuel leak troubleshooting. Fuel pump outlet- installed Del washer and retightened b-nut- appears solved.
Fuel pump inlet- removed and installed new Del washer- took two different tigthening attempts, but it appears to have stopped- will check tomorrow.
Installed the new mini thermocouple connectors to all CHT probes. Pulled wiring snug and bundled excess inside cabin. Tied up remaining wiring.
Adjusted adel clamps on prop gov cable to remove interference with crankcase breather.
Worked on tieing up wiring aft of baggae compartment.
Looking for and fixing any loose wire bundles.
No more Red Xs
RV-10 Home
3570
330
284
918
1411
579
