Flandy Rv-10
RV-10
FWF Day #10
Finished installing GPS shelf.
Removed Turbo--Torqued housing bolts and reservoir. Installed oil supply hose.
Reinstalled turbo and tightened all mounting bolts. Tightened exhaust V-band clamps per MTC manual.
Installed all oil hoses to turbo.
Filled oil system and checked for leaks-- found oil one and tightened.
Primed fuel system using boost pump. Found one leak at connection to low pressure pump outlet to fuel filter.
RV-10 Home
3570
330
284
918
1411
579
