Flandy Rv-10
RV-10
Misc work
Completed wiring fuel cooler butterly valve- check out complete.
Pitot heat light wasn't working- found ground wire at power sensor disconnected. Fixed.
Using prop cable, determined length of throttle cable. ordered from ACS.
Removed throttle quadrant and modified cable mount to hold bulkhead fittings slightly lower than regular unit.
RV-10 Home
3570
330
284
918
1411
579
