Flandy Rv-10
RV-10
Fuel system- Part Deux
Ok, decided that it made sense to reverse the supply and return lines locations as the pass thru the FW.
The least expensive but more time intensive way is what I choose.
Moved the Fuel sensor mount on FW from right to left side. Will make connecting to engine supply easier.
Refabricated the Red Cube mount and Fuel pump mount. Due to new alignment of fuel pump and Red Cube connections, the plumbing line needs to be remade.
Still need to redrill the fuel pump bolts and supply red cube bolts and install nutplates.
RV-10 Home
3570
330
284
918
1411
579
