Completed modification to aft throttle mount to support Van's Rv-10 throttle unit that is modified for this engine installation.
Worked on ECU throttle input mounting.
Reconnected fuel float ground as proseal seems to be cured on surface. Powered system and saw a voltage reading in the calibration that looked normal for the 1 gallon added to keep float off bottom.
Sealed and tied off Rudder Trim wiring to complete the install.
