Flandy Rv-10
RV-10
Panel Work Day #7
Recieved the repaired parts for Flightdata systems.
Installed and tested new LED for GD-40. Works as advertised and quite bright this time.
Hooked up the box for the AN-21 annunciator system. Worked correctly. Swapped door light inputs so they worked with the correct door.
Wired up the Rudder trim and tested. Pushrod may need adjusting but it worked.
Tried to calibrate the rudder trim and flaps in the G3X. Need to read more as it wasn't working right.
RV-10 Home
3570
330
284
918
1411
579
