Flandy Rv-10
Date:  9-19-2014
Number of Hours:  2.50
Manual Reference:  12, 24
Brief Description:  Fairings
Finally got a some time off from training, so I put some work on the fairings.
Rudder bottom fairing-- sanded filler to blend with aft rudder edge. Ready for surface primer.
Right wingtip-- removed fairing stiffener and drilled new W-1016-L stiffener in to right wingtip. Decided to add a .040 shim to the bottom so that the fairing matches the aileron profile better.
Started bonding tip outer edge back together with flocked epoxy.
