Flandy Rv-10
RV-10
44-9 to 44-12
Wing roots and HS/elevator
Drilled root fairnings for nutplates. Deburred,dimpled and riveted nutplates per plans to inboard fairing supports.
Marked were fuselage wire penetrations will be drilled.
Pulled wings to prepare for final assembly.
Continued sanding and filling process on HS and Elevator tips.
Riveted right side fairing supports. Drilled, deburred and installed snapbushings on right side for wire penetrations.
Riveted tank forward fuselage attachment pracket to tank.
Started riveting left side fairing supports but ran out of LP4-3 rivets and more importantly, the desire to keep working for the day.
RV-10 Home
3570
330
284
918
1411
579
