Started masking off forward windcreen for installlation.
Drilled forward side panels for cup holders and pockets.
Marked and drilled replacement overhead access panel for passenger lights and dimmers.
Drilled and dimpled rudder trim access panel for #6 screws to hold actuator. Marked and drilled intial hole for actuator rod. Worked on elongating hole for rod. Needs more adjusting.
