Flandy Rv-10
Date:  6-19-2013
Number of Hours:  5.50
Brief Description:  GMC305+ Door Warning
The autopilot MCP was waiting when I returned from Brazil this morning. Marked panel and cut out opening. Filed edges for a nice fit. Drilled four corner attachment holes. Started working on wiring connection but need to talk with Stein about moving inputs on #1PFD to make room.
Marked new locaiton for GX pilot contol head and drilled corner screw holes. Started removing material.
Decided to leave door warning sensor mount behind alternator regulator. Completed wiring power and grounds and inputs to AN-21 for lights. Just need to install reed switches to complete.
Replaced Nav light switch witha 700-2-10. Wired power to switch. Completed wiring sheilded bundle to switch and ground. Routed and tied wire through tail cone and added an adel clamp near GPU plug to support wires.
