Completed wiring power and ground to the following:
Main Batt Contactor Aux Batt Contactor Alt power switch/breaker Main Avionics switch Ess. Avionics switch Pitot heat power TCW trim power switch GPU switch/breaker Dome Lights
Power connected to
L+R Xfer pumps Main boost pump
Wired 10 LED annunciator light panel for power and ground input to AN-21 controller.
