Flandy Rv-10
Date:  5-5-2013
Number of Hours:  2.50
Brief Description:  Panel and power bus integration
Started working on possible wire runs behind panel. Installed panel with Ahars mount. Engaged main power camlocs and drilled temporary marks for receivers. Realized the essential power block mount was too short. Removed and remade mount. Temporarily installed and drilled camloc holes in mount and panel. Marked and drilled holes for camloc receivers. Removed panel and final drilled receiver holes and riveted left camlocs in place. Missing one part so right side will wait for an ACS run.
