Started today by doing some cleanup work on a few open items.
Pinned up the power cable for the elevator trim and tested movement with 9v battery. Then installed unit in place for safe storage. Also installed ELT and connected antenna cable.
Located and drilled center cam block on left door frame. Drilled #12, deburred and bolted in place. With this installed, Tracey helped me mark the door frame for the locking pins. Drilled them to 5/16" and then slowly expanded holes to 7/16" keeping door fit correct. Did some additional filing of door edges for a better fit in the door frame.
