After allowing the static ports to cure for two days, I cleaned up any excess chemseal off the outside of the tailcone. Crawled (wedged) my self back into tailcone and cut tubing to connect both ports. Installed adel clamps to hold line in place making sure it could not rub against fuselage.
Drilled hole and installed snap bushing where it passed through a bulkhead. Need to install one more clamp before tubing enters conduit to pass under rear seats.
