Actually, today was the two steps backwards following the one step forward. I had used a roller to put on the last coat of UV smooth prime- big mistake. I had to sand every bit of this off because it was no where close to being smooth. Using only a paint gun for the next coat. But I did find several areas that needed more filler before next coat. This was the same for the cabin cover and both doors.
Split the main wheel pant halves, removed tape and then reassembled before sanding. Will take a couple more times, but it is starting to look good. Filled more holes on pants and left to cure.
