Brief Description: Cabin Cover Day #32, Doors Day #19, Tires
Checked the left main tire to see that grease seals were correct- they were. Double checked the outer rim of the nose tire seal greased properly. Set the preload for the axle per Matco documents. Installed nose tire on front fork.
Spent a couple hours working on sanding cabin cover door posts and front windscreen perimeter. Did more filling of holes on inside of doors. Once it cured, those areas were sanded.
Mixed up a 50/50 mixture of epoxy and acetone. Coated inside of both doors and the cabin cover to start filling pinholes.
