Brief Description: More doors day #7 and panel work
Finished drilling last delrin block on left door.
With all parts installed, checked actuation of locking mechanism and marked pushrods for trimming in full closed postion. Left door had excess structural filler blocking mid rack from full range of motion. Took awhile, but that problem is now solved.
Removed all parts except gear block. Trimmed pushrods. Now for cosmetic work on doors.
Continued tweaking radio rack mounts. Marked instrument panel for rivets and drilled. Then match drilled radio rack supports to panel. Marked sub-panel for radio rack cut-out.
