Flandy Rv-10
RV-10
Locks, Door Frames and Panel supports
Drilled door frames to 13/32" and fitted new delrin blocks to each door location.
Drilled a 1/8" holes 3/16" from the new cut end of the racks. Installed a LP4-3 rivet in opposite end per plans.
Compressed spring on door handles and insterted Picolo tube in door handle and installed retaining pin. Need to prime parts prior to continuing.
Sanded left door frame opening and then added more filler material to both door frame openings to square off edges.
Switched to panel work and fabricated new rack to panel support mounts. Much better fit this time.
RV-10 Home
3570
330
284
918
1411
579
