Continued trimming left door to fit. Fit close enough to drill hinges. Taped left door in place and drilled one hole in each hinge. Inserted and tightened nut and bolt in each. Drilled and countersunk other bolt hole. Inserted hardware and then remove first set and countersunk. Reinstalled hardware. Opened door and and drilled remaining two holes in each hinge. Countersunk and installed hardware.
Continued trimming right door to fit. Cut tabs off and trimmed more. Taped door in place and drilled hinges in same sequence as left door. Forward right hinge rides a little low, so a shim is required.
