Marked and bent the F-1068 A+B sub panels per plans. Clecoed sub-panel and forward fuselage ribs together, then match drilled #30. Inserted F-1044 A+B angle and spacer into sub-panel.
Using long #30 bit, drilled hole through upper firewall angle into firewall recess. Clecoed sub-panel structure onto fuselage. Match drilled sub-panel to F-1002 L+R. Match drilled and clecoed Angle and spacer to forward rib in two places. Match drilled #30 up through firewall recess into F-1044A Angle.
Match drilled #19 and #40 the holes in the F-1003 instrument panel and F-1003B lower instrument panel flange.
Need to make decision on whether I will use Van's two part panel or a seperate one piece unit.
