Trimmed both baggage door seal parts. Clecoed the seat back brace, spacers and both F-1046 L+R longerons in place. Match drilled right side.
Final drilled #19 and countersunk the holes in the side of both F-1015 mid cabin deck parts. Clecoed same in place and installed both L+R longerons. Match drilled #40 common holes.
Marked the F-1070R skin per plans and clamped to the table. Using much force, bent the skin into desired shape and finished forward bend with the tap of the rubber mallet.
Clecoed and match drilled #30 and #40 appropriate holes in the F-1023 baggage floor angle.
Clecoed F-1070 R mid side skin and F-1015F space to the under structure.
