Since I'm waiting for someone to help rivet, I've started on next section.
Separated 1043C attach angle and match drilled to fwd fuselage rib. Match drilled and C-sunk nutplate holes. Clecoed the 1043G+H fwd seat rail supports together and match drilled. Clecoed the 1043E+F parts to make inboard seat rail supports. Match drilled and C-sunk. Match drilled and C-sunk the 1042 L+R bulkhead side channels per plans. Marked, trimmed, and drilled 1033 control column mount per plans. Clecoed the following together- 1042 bulkhead side channel, 1043B fwd fuselage bulkhead, inboard and outbaord fwd seat rail supports, 1043C attach angle, 1043D fwd cover plate, 1004K fwd section side plate, and 1043A fwd fuselage bulkhead for the L and R side. Final drilled as appropriate #30 and #19.
Bolted control column mount to fwd bulkhead and clamped parallel to inboard seat rail support. Match drilled remaining three holes.
