Flandy Rv-10
Date:  8-16-2010
Number of Hours:  5.00
Manual Reference:  27-2,3,4,6
Brief Description:  Drilled and Deburred Firewall
Finsihed deburring the mid fuselage ribs- yea!
DImpled and riveted the firewall recess.
FInal drilled #40 and #12, the16 nutplates on the firewall. Match drilled #30 all remaining holes on firewall.
Laid out and drilled the scat tube support on the right fwd fuselage rib. Removed the WD-1004 nose gear tension fitting and the F-1001E center angles from the firewall and clecoed to fwd fuselage ribs L+R. Clecoed flanged ducts and tee to fwd ribs. Match drilled assembly #30. Match drilled the nutlplate holes on the fuselage ribs. Also match drilled the F-1048 fuel valve bracket in place. Match drilled the F-1039D rudder pedal brace.
Disassembled all structure and countersunk all parts as appropriate for firewall dimples. Continued deburring all aluminum parts.
Now you see it...
Now you see it...
Now you don't  UGH!!!
