Today it warmed up to a toasty 51 degrees farenheit so I took the opportunity to scuff and prime the remaining floor ribs. Then, I riveted and assembled the ribs together on the 806 bulkhead. Next, I had to do the tricky fitting and drilling of the two inner floor ribs to the center section. It turned out very good. The two end floor ribs were then riveted and bolted to the 806 bulhkead. Next, I have to prime and rivet the angle that holds the two inner floor ribs to the center section. I also have to fit two final floor ribs to the rear of the 806 bulkhead and fabricate the rear crotch strap fitting.
