First I re-checked the baffles/top cowling to make sure everything fits okay. One baffle needed a little trim. Once that was done - perfect.
Next, I installed the oil cooler. After all the bracing, the oil cooler is really rigid. You could tow the plane with the oil cooler - really, really solid.
Next I worked on the Anti-Splat Oil Separator. I put a doubler on the firewall and placed the separator - looks really good. I ordered the instal kit, but the kit does not include the saddle to drop the exhaust gases into the engine exhaust. I ordered that.
Tomorrow, I will start to tack on the baffle gaskets.
