I painted the spar pieces in an earlier step, but just decided to include that here. The hinge brackets had to be installed before the rear channel because the rivets had to be pulled from the inside. Everyting seemed to line up ok, but now I have to re-measure and locate the cenrter line and other important locations in order to install the foreward and rear spars. The balance weight is not installed at this time.
