Steves S-20 Build Site.
Date: 9-4-2016
Number of Hours: 12.00
Brief Description: Painting the Stabilizers.
The last day of my first paint marathon!!
I was very pleased with the way the elevators came out, and my confidence as a painter is building.
Today it was the color coats for the stabilizers. I started by temporarily attaching the newly painted elevators and lining up the templates watching to make sure I had straight lines across the panels and that the taper transitions to the leading edge correctly.
With the first template in place and taped off, I sprayed red. I used the drop-off portion of the template that represents the black area to locate the remaining template covering the red I do not want to get paint on, and taped it off and the rest is a matter of procedure.
The biggest issue I had with the stabilizers was the bugs. By the time I was applying the clear coat it was after midnight and I had my shop door open most of the evening to allow paint fumes to exit, but this also lets the bugs in. I originally had furnace filters on my paint booth outlet, but they plugged up pretty fast so I replaced them with a fine window screen material that is supposed to prevent even gnats from entering. Other than that my paint booth is pretty tight, and I thought it would be all but impossible for a bug to fly into the fans and get through the screen, but apparently some bugs can get in. I spent about a half hour trying to find and swat them all, but I still ended up spraying clear with one hand and grabbing bugs out of the air with the other.... One did get into the clear, but I got him removed right away, and thankfully none ended up in the final product....
So, I have my first major painted parts and I can't be more excited. They are not perfect, and a painting professional will be able to find some orange peel, some trash, and even a bug carcass in one of the elevators, but for a first time painter in a makeshift paint booth I am ecstatic about the results so far (firmly knocking on wood right now...).
On to the rudder!
Locating the templates to match the elevators.
Ready for the red.
The results of my memorial day weekend! Yee Haw!
