I spent a several weeks wiring the avionics. I made a lot of personal notes so I can maintain the systems later, but I didn't take many pictures to document the process.
One of the most valuable items I had for the wiring was a laber that prints on heat shrink tubing, Several times I would select a section or compoent to wire, then spend some time figuring out and labeling each wire. Then the job of connecting them was easy. I have also already found the labels to be invaluable for determining the function of wires as I continue to assemble the airplane.
The only other comment I would have would be to take your time and plan ahead. neatness counts, and being able to access everything on the completed plane will save agravation in the future.
