I knew that the bottom edge of the plastic side panels for the station 3 closeout would need an additional tab added to secure them. I made this tab out of some scrap 1/2" wide aluminum, and riveted to the baggage panel sides.
On my parts, I found that the center of the side panels also needed some guidance to fit nicely. To cure this I used a "P-clamp", a 10-24 coupler nut, and a nylon screw to hold the side panel to the frame tubing.
I cut the top off the plastic side panels also for a better fit. Overall, this part of the kit could use some fit and finish enhancements, but I think it really dresses up the first impression of looking inside the plane since all the cables and wires at the entrance to the baggage compartment are covered up
