Todd’s RV14a
RV14a
AFT Fuselage
8-1-2018
Aft fuselage
Clecod and match drilled the F-1412A and B bulkheads to the aft spar of the vertical. Debured and Primed with Sem self etching primer.
10-6. Rounded the edges of the flanges with a scotch brite wheel. Dimpled the flanges in a couple spots for the access cover.
10-09. Riveted the bulkheads and tie down bracket as per steps 1-2.
RV14a Home
683
AFT Fuselage
Aileron Actuation
Aileron Both
Elevator
Empange Attach
Fairings
Firewall
Flaps
Flight Controls
Fuel
Horizontal Stabilize
Instrument panel str
Interior Paint
Left Aileron
Left Wing
Left wing fuel tank
Left wing Leading ed
Lighting
Magnetometer mount
Pitot
Right Aileron
Right Fuel Tank
Right Wing
Right Wing leading E
Rollbar
rudder Pedals
Spar
Vertical Stabilizer
Wing bottom skins
Wing bottome skins
Wing Wiring
