Finished up 9-22 steps 1-4 with counterbalance ribs. Finished riveting as required.
9-23. Steps 1-7 Applied the 3M tape to both sides of the trailing edge E1423. Mixed tank sealant and applied to the 2 E-924 ribs. Installed and clecod together the trailing edge for a couple days to cure. Will finish later after drying.
Finished up riveting the trailing edge of the trim tab. Double flush rivets via backriveting. Looks pretty good. Does not fill the dimple as stated but is flush with the skin.
