Todd’s RV14a
RV14a
Right Wing Build
Began right wing build.
Steps 1-5. Fabd the J channel as called out in the steps. Matched drilled the j channels.
13-03 Final drilled the spar flange. Machine countersunk the nutplate holes. All looks good.
Step 3. Machine counter sunk the flange locations not already done.
Step 4. Riveted the fuel tank skin nutplates into place.
Riveted the wing access nutplates.. Spot primed where the countersinking was done.
Installed snap bushings.
13-05. Steps 1-3. Final drilled the web rivet holes and installed nutplates.
STep 4. Final drilled the #12 holes in aileron bracket and attached to spar with bolts.
RV14a Home
683
AFT Fuselage
Aileron Actuation
Aileron Both
Elevator
Empange Attach
Fairings
Firewall
Flaps
Flight Controls
Fuel
Horizontal Stabilize
Instrument panel str
Interior Paint
Left Aileron
Left Wing
Left wing fuel tank
Left wing Leading ed
Lighting
Magnetometer mount
Pitot
Right Aileron
Right Fuel Tank
Right Wing
Right Wing leading E
Rollbar
rudder Pedals
Spar
Vertical Stabilizer
Wing bottom skins
Wing bottome skins
Wing Wiring
