Glued windscreen to fuse using Sikaflex (German) adhesive, a 3 step process. after masking and scuffing, you apply activator ($57 bucks a can and it smells just like alcohol), then primer, then adhesive. Turned out pretty good.
Also built a stand to hold the rear canopy so I can work on it off the plane. Also fits on top of sawhorses so I can get inside to work.
