Brief Description: Cut elevator motor plate to fit.
Trimmed to fit the trim tab motor plate. Was 1/4" to long. Then re-bent the forward tabs to lay flush with elevator the spar tube. Made hole in tube larger so the elevator motor jack screw would not rub. Step drilled out the 4 hole to #19. Will prime the plate today with the stab parts.
