GLENN'S WEB SITE
AirCam
Horizontal Stabilize
6-1-2014
4th rib
Drilled out center hole to 5/16" then cut slot on rib. Then drilled out 10 #40 holes into side of the 4th rib as per page 5-23. Done for both left and right.
5/16" slot
#40 hole 1/4' from edge
AirCam Home
547
Ailerons
Center wing
91
229
Elevator trim tab.
Elevators
Flaps
Fuel Tanks
Paint booth
Vertical Stab
