I decided to buy ribs from Aircam and trash the ones I made earlier in the year. I cut the ribs down and installed them in front of each fuel tank to add more streanght to the skin at the recommendation of many builders who say when the put a fuel can up on the wing for fueling, the skins are soft in this area. I mounted the ribs the same as the other ribs using AC-CT -002 and AC-CT-022 parts obtained from Aircam. Also added a support stringer behind each rib. I attached the ribs to the stringer with 2 l brakets.
