Brief Description: Finished the access hole in lower center wing
I received my 3/4’ inch piano hinge. I cut it to fit in the stiffener I made. I cut and drilled to #29 the the stiffener, and drilled the hinge to #19 and then I also added a second stiffen on the hinge.
