Brief Description: Added nose ribs in front of fuel tanks
I traced a rib before installing and then made two nose ribs to add in front of the fuel tanks. I was told by some Aircam owners the skins seemed soft in front of t tanks so I decided to beef them up. I added the 2 extra ribs and attached them to the front spar using 4 AC-CT-002 from the factory, and made my own AC-CT-021 from traced parts. Also made and extra AC--CT-052 for added strength in front of the fuel tanks. I will rivet together after they are removed for de burring and primer.
