Brief Description: Install fuel tanks in center wing
I clecoed on the lower and upper aft skins to square up the center section. Installed the tanks.All went well acept the mounting holes on one take did not line up well. Lockwood said it was ok to dril out the holes to fit. Some shims where used to make the fit tight.
