GLENN'S WEB SITE
AirCam
intall 4th rib and componets
Instlled the bolts through both HS-006 wire attachment brackets. Drilled out to #19 and the added 4th rib againt 5th rib and drilled out to #29. Completed for both rear and front spar and both left and right.
4th rib clecoed to 5th #29 holes
AN4-6A bolt
HS-006 bracket
AirCam Home
547
Ailerons
Center wing
91
229
Elevator trim tab.
Elevators
Flaps
Fuel Tanks
Horizontal Stabilize
Paint booth
Vertical Stab
