Assembled front par to ribs with clecos then attached the root rib and cable attachment bracket to spar and also HS-012 spar attachment bracket. drilled 6 outer hole to #30 and 6 inner holes to #19. Also attached the first nose rib. Took apart and deburred. Completed for both left and right spars.
