Riveted step attach angles to step ribs. Clecoed step bulkhead back in place and riveted it to step ribs. Riveted nutplate brackets and step attach angles to the bulkhead. Riveted the bulkhead to the corner skins. Trial fitted steps. Installed nutplates to step bulkhead, as directed. Installed snap bushings into the step bulkhead. Removed protective vinyl and deburred left and right step floors. Dimpled left and right step floors and nut plates and riveted nut plates to step floors, as directed. Riveted the left and right step floors to the bulkheads, step ribs, and seat floor supports, as directed. Removed protective vinyl and deburred the baggage bulkhead. Dimpled baggage bulkhead and nutplates and riveted same.
Right step attach angles and nutplate brackets riveted in place - Left is similar
