Crimped male Molex pins on ends of wires coming from the left and right Nav/Position/Strobe Lights, as directed. Snapped the male Molex pins into the female Molex left and right connector housings, as directed. Labeled the Molex connector housings as to which wire is in which position. Connected the Molex connector housings together for the wing tip nav/position/strobelights - red & green. Slid the wires and connector housings back into the wing tip through the opening in the left and right extensions then slid the lights onto the mount brackets & tightened them in place with the set screw at the aft edge.
Right Wing Tip Nav/Position/Strobe Light (Left similar)
