Clecoed left and right extension to wing tips. Masked areas for sealant with electrical tape as directed. Removed left and right extensions from the wing tips and added a thin layer of fuel tank sealant on the lower flange that interfaces with the wing tip close-outs. Pulled the male Molex connector housings through the hole in the left and right extensions, then clecoed and riveted the extensions to the wing tips. Filleted the fuel tank sealant that extruded out around the lower flange of the left and right extensions. Removed tape.
Left Wing Tip Extension Riveted in Place (Right is Similar)
