Steve & Nancy Riffe
Date:  9-23-2013
Number of Hours:  1.00
Brief Description:  Misc Stuff
Installed the battery tray followed by the battery. Connected the positive feed from the battery to the master solenoid—will leave the negative side unhooked for now. I’m ready to install the gear, but I’m still waiting on an engine hoist from Harbor Aircraft Supply—been on backorder for over two weeks now. Tonight I dug out parts for mounting the axles and wheels. I edge finished the U807 wheel pant attach brackets—they looked like they had been cut out with a chain saw. I had received some screws from ACS to mount the Suntail nav/strobe to the rudder tail mount ring. The first one seemed pretty tight and sure enough, it twisted off. I was able to get some small vice grips on the edge and removed the screw. I finally found a 4x40 tap and ran it thru the holes in the tail light mounting ring. The screw now goes in without problem—however, now I’m short one screw.
Installed tray and battery
Wheel pant attach brackets
Ran tap into tail mounting ring
