Steve & Nancy Riffe
Date:  10-8-2012
Number of Hours:  1.00
Brief Description:  Rudder cable fairings-3
Back to rudder cable fairings tonight. Pretty much a repeat of the fairing on the left side. Match drill, c/s, deburr, prime and pop rivet to fuse. Both sides turned out pretty well. Word of caution, be sure you have the nylon sheath that the cable runs thru installed before you add fairings, or you might have to remove the fairing to get the sheath thru the fuse skin. Only got one pic tonight. Spent the rest of my time panel planning.
Rudder cable fairing-right side
