Steve & Nancy Riffe
Date:  4-4-2012
Number of Hours:  1.00
Brief Description:  Battery cable run
Finished securing battery cable all the way to the battery box area. In the area just behind the spar, it is difficult to bend the cable enough in order to maintain clearance with the aileron push tube. May decide to add one more adel clamp toward the end of the run. Cut the excess cable off using a cutoff wheel on the dremel. Stripped some insulation back in preparation to adding terminal lug.
Just clears the aileron push tube
Cut excess cable off
End of run-this is where cable connects to contactor
