Steve & Nancy Riffe
Date:  1-6-2012
Number of Hours:  1.00
Brief Description:  Baggage Door Lock Pins
Cleaned up the edges of the F873L lock arm. Cut the F873K pins from a length of aluminum tubing per plans. Drilled holes in the end of each pin to 1/16”, then drilled up to 1/8”. Cut a slot with hacksaw, then used a thin file to open the slot to 1/16”. Radiused the ends of the pins. Opened up the snap bushings using a step bit which I turned by hand. Then opened them up very slightly with a pointed stone in the dremel until the pins slid thru with little friction.
Shadow on pic, but drilling end of pin
Opening slot with thin file
Pins and lock arm
Pins and lock arm
