Steve & Nancy Riffe
Date:  8-20-2011
Brief Description:  F839, F840, F841 Control Tubes-Finish
Poured primer into the F840 tube and slowly tilted the tube back and forth. After about 10 minutes of this, I poured the primer into the F841 tube. Then I added a bit more primer and went thru the same routine as the F840 tube. Emptied the primer into a can and removed the tape left the primer to dry. Later in the day, I checked and the primer was dry—Texas heat tends to dry primer rather quickly. I dipped the end caps in primer and shoved them into the tubes. Then I dipped the pop rivets in primer and pulled them with the hydraulic riveter. I cleaned and scuffed the outside of both tubes and shot them with primer. Adjusted the length of F839 tube per plan specs. Done with the three control tubes.
F840 tube primed
F840 tube primed
F841 tube primed
F841 tube primed
