Riveted the F635 bellcrank together using the pneumatic squeezer. Measured and marked the length to cut the F841 and F840 per the plans. Used a tubing cutter to cut the F840—need to pick up a larger cutter for the F841. Used folded paper method to mark location of the eight holes in one end of the F841 and inserted the bearing cap.
